Work Item Permissions and Data permissions
It is possible for work items to be shared with you, yet still not see the expected results. Below is an example where a dashboard was shared with Write permission. The dashboard itself is accessible, and the underlying work items, such as TrendHub views, are also reachable. However, I do not have access to the data source used by the components that build these views and tiles.
To fix this, contact your System administrator and request access to the relevant data source in ConfigHub. Once access is granted, the components should load correctly and display the expected data.
