Application Enhancements
Dark mode contrast has been improved by adjusting the black/white color threshold, resulting in better readability across all views.
Every ConfigHub overview and detail page now follows the same layout and navigation pattern, so admins get a consistent experience across all configuration sections.
TrendHub - Performance of plotting context charts spanning multiple years have been increased.
TrendHub - Scatter plots in a multi-scatter view now share a single color gradient, so the same color represents the same value in every plot and you can compare plots directly.
TrendHub - Duplicating a calculation now opens a pre-filled Duplicate calculation form, where you enter the name and adjust the operation before the copy is created. You no longer have to create the duplicate first and then edit it afterwards, which makes it quicker to build up a set of similar calculations.
