Bug Fixes
  • DashHub - The date range operator was ignored when used with a global time frame in dashboards. Date range filtering now works correctly alongside global time frames.
  • ContextHub - Synchronous batch context item creation set the createdBy field to the service account instead of the actual user. The correct user is now recorded.
  • Work Organizer - The lastModifiedDate was not updated when a saved item was modified, causing stale timestamps in the overview. Modifications now correctly update the date.
  • TrendHub - Fixed an issue where the value on the data scooter could be pushed outside its container after moving the scooter, so the value no longer overlaps the surrounding chart.
  • TrendHub - Fixed an issue where zooming in to a period shorter than the minimum duration of a search based filter caused the whole time window to be filtered out. The filter now evaluates the search in the broader time context, so results stay correct at any zoom level.
