Index manager and performance overview
The Index Manager is only available to users with the 'application administrator' role. This role can be assigned via user management in ConfigHub.
The first time a tag is used, either by adding the tag to the focus chart or by running a batch-indexing script, the full history of the tag will be indexed. Afterwards, TrendMiner will keep the indexes of these tags up to date. More information on the mechanism behind indexing and how this impacts TrendMiner features can be found here.
The Index Manager in TrendMiner serves as a robust tool for application administrators, enabling them to effectively manage tag indexes and evaluate overall indexing performance.
When upgrading TrendMiner 2025.R1.0 to a newer version, an index migration will be performed. The status of the migration will be indicated at the top in the index manager. On successful completion, the status indication will disappear 1 week after completion.
During the migration, no indexing will be performed. In case of failure, please reach out TrendMiner support.
Navigation
The Index Manager is divided into two main tabs, each serving a specific purpose:
The Index Overview tab offers a comprehensive summary of all tags indexed within the TrendMiner system. For each tag, the following details are provided:
  • Datasource name: This column indicates the name of the datasource linked to each tag, assisting administrators in pinpointing the data's origin. Tags created within TrendMiner are marked with an Internal label.
  • Index start date: The point in time up until we have indexed tag data. For tags that have been successfully indexed, this date should align with the configured horizon.
  • End of data: Date of the last known index point in the TrendMiner index storage. This date is updated when new data points are added to the index.
  • Last update: The latest attempt by TrendMiner to update the index, whether successful or not.
  • Update cycle: This column outlines the update frequency for each tag, indicating how often the datasource is checked for new data.
  • Status: An indication of the overall health of the tag (refer to the table below).
For a healthy system, the Last update period should be within or close to the specified update cycle. The Last update value shows when TrendMiner last attempted to update the index. The End of Data value, however, updates only if a new data point was received during this attempt.
For each tag, the following actions can be performed:
  • Refresh index: This action deletes and recalculates the index and the index policy of the current tag. It will also automatically delete the index of any Tag Builder tags constructed on top of the refreshed tag.
    A refresh of an index can be useful in case data has been modified/corrected in the datasource itself after the initial storage. Such updates are not automatically picked up by TrendMiner.
  • Delete index: This action deletes the index of the current tag and automatically deletes the index of any Tag Builder tags constructed on top of the deleted tag. Since tags which are used in monitors are required to have an index, they can not be deleted.
    Deleting an index can be useful to free up storage or to clean up Stale tags.
Once a tag is indexed, TrendMiner continuously keeps its index up to date. This ensures smooth access to time series data while distributing the load on data sources throughout the day.
A tag is updated according to one of the following update cycles:
  • Every 2 minutes
    Tags in active monitors are updated every 2 minutes. In case calculated tag are monitored their variables are also updated every 2 minutes. The 2 minute update cycle gets priority over all other cycles.
  • Every hour
    This is the default indexing policy. Tags are updated hourly once initially indexed and remain on this cycle as long as they are actively used[1].
  • Every day
    This is the reduced indexing policy. Tags that haven’t been used[1] by any user in the past week will be updated once per day.
  • Never
    This occurs when a tag is marked as Dormant (see Index States Overview). To conserve resources, TrendMiner will no longer attempt to update these tags.
Tags unused[1] for a week are identified daily and automatically switched to the reduced indexing policy. If such a tag is used again, it will revert to the default policy within 5 minutes.
The Index Manager screen categorizes tags into various index states, each indicating the current status of the tag's indexing process:
Index State
Explanation
Tag completely up to date. Backwards indexing was successful and recent data was successfully appended.
Backwards indexation process in progress.
The index state will switch to OK after completion. Data which is indexed can already be used in the analyses.
Backwards indexing was performed but an error (e.g. historian connection loss) occurred during this process.
The Index start date indicates where the backwards process stopped.
The indexation will automatically be retried when the tag is used again (e.g. the tag is added to the chart).
Since the index state 'Out of date' gets priority over the state 'Incomplete' an incomplete state indicates an indexing issue related to one specific month in the tag history, and not a structural connection issue with the data source (if no recent index data can be fetched either the tag will show an 'Out of date' status). In case of a calculated tag the issue can be caused by an indexing issue for one of the underlying tags. For a historian/data source tag the issue could be related to wrong data being returned for a specific time period or out of order points due to a daylight savings time switch.
As a result the incomplete status implies that recent data was successfully appended for the tag.
Recent data was not successfully appended (e.g. due to historian connection issues), delaying potential monitoring events.
This state gets priority on incomplete state.
Continuous indexing will keep trying to update this tag's index, even if the tag is not explicitly used.
TrendMiner is no longer able to update the index of the tag. This can happen when a tag or one of the tag variables is deleted or when the connection to the data source has been removed.. TrendMiner will disregard these tags when updating the most recent data. If the root cause is resolved, the indexation process will automatically resume when the tag is used again.
In case the corresponding datasource is removed permanently, these indexes can be deleted from the index overview.
The current tag did not receive any new data for a full year (End of data is more than 1 year ago). To save resources, TrendMiner will no longer try to index this tag (Update cycle will show Never) . In case this tag is used in a monitor, the Dormant state is ignored and TrendMiner will keep trying to update this tag every 2 minutes.
Dormant tags are identified once a day by an automated process.
When plotting a Dormant tag in the focus chart, indexing will be retriggered and the tag will resume its normal indexing status. Administrators can also manually resume forwards indexing of these tags by clicking the play button in the index manager. If the indexing call did not receive any new data, the tag will automatically go back to Dormant once a new identification process runs.
Administrators can filter the view based on the different columns to quickly locate specific tags or identify issues.
  • Index status
  • Delayed status
    • A tag is considered delayed when its latest update attempt exceeds four times the set update cycle duration. Stale and Dormant tags are ignored when filtering on Delayed tags.
  • Max update cycle time
  • Data source name
Once a tag is used, an index is created and updated automatically. (See the section above for details on the different update cycles.)
A tag is marked as delayed when its latest update attempt exceeds four times its assigned update cycle. This means a tag is considered delayed if its last index attempt occurred:
  • 8 minutes ago for monitor tags (2-minute cycle),
  • 4 hours ago for default tags (1-hour cycle),
  • 4 days ago for reduced-cycle tags (1-day cycle).
Tags with higher percentage-based delays are prioritized for indexing to minimize delays—especially for those used in monitors.
You can filter the Index Overview to show only delayed tags. Note that this is not an official index state, but a derived status based on the tag’s update cycle and its last update attempt.
Delayed tags are a useful KPI for assessing the performance of a specific data source or the overall TrendMiner system (see the section on interpreting these values and identifying potential bottlenecks).
Difference between Out of Date, Index state and Delayed tags
It’s important to distinguish between index states and the delayed status of a tag:
  • Index states like Incomplete or Out of Date typically indicate an issue with the data source or the data query itself.
  • Delayed status reflects how efficiently TrendMiner is able to update tags within the expected time frame.
Examples:
  • A tag can be OK but delayed if the connected data source is too slow to fetch data for all tags within the desired window.
  • A tag can be Out of Date but not delayed if the data query fails, even though update attempts are made on time.
The Performance tab visualizes a card for each connected and internal time-series datasource. Each card provides the following detailed information:
  • Number of Indexed Tags: Displays the total number of tags that have been indexed for this specific datasource.
  • Number of Tags per Index State: Shows the distribution of tags across different index states.
  • Number of Tags per Index Refresh Policy: Shows the distribution of tags which should be indexed hourly or every 2 minutes.
  • Number of Delayed Tags: Indicates the number of tags that are delayed in their indexing process.
  • Dropdown with Metrics: Provides additional metrics on historian performance, offering deeper insights into the datasource's indexing efficiency. More information on how to interpret these metrics can be found here.
Sorting Options
Datasource cards can be sorted to prioritize the information most relevant to the administrator:
  • Number of Indexed Tags: Sort cards based on the total number of indexed tags.
  • Number of Delayed Tags: Sort cards based on the percentage of delayed tags.
Interactive elements
Both tabs feature clickable links and labels, enhancing navigation and usability. These interactive elements allow administrators to easily switch between tabs, providing a filtered overview based on the respective link. By clicking, for example, on the Stale label of a specific historian on the performance Tab, the index overview will be opened, filtered on tags with an index status Stale, belonging to that specific historian.
Measures to limit load on the data sources
To keep indexes up to date, TrendMiner continuously polls data sources for new data. While data querying is already optimized by distributing the load throughout the day, additional measures are in place to avoid unnecessary requests:
  • Dormant Tags
    Tags classified as Dormant (see Index State overview above) are excluded from the update mechanism, preventing needless polling.
  • Reduced Update Cycle for Unused Tags
    Tags that haven’t been used recently are switched to a reduced update cycle, updating only once per day. This significantly lowers the number of data requests.
Diagnosing performance issues
The index manager provides a lot of information allowing the application administrator to diagnose indexing related issues. Although setups can be very different across different customers, requiring different optimizations, the current section provides some general guidance.
A healthy system should reflect the following criteria:
  • (almost) all tags in OK indexing status, or In progress
  • no delayed tags in the performance overview
In these cases, it is good practice to check to which historian these tags belong. Out of date or Incomplete states happen when TrendMiner tries to index the tag, but an error occurs when trying to fetch the data.
If a lot of tags originate from one specific historian, there might be a connection issue. In case this only happens for specific tag, there is most likely a data quality issue (for example out of order points being returned by the historian).
Delayed means the tag status is still OK but the last updated date is > 4 hours or 8 minutes (monitors)
Scenario A: historians are performing well
Since a lot of tags are delayed but the historians are performing well, it is likely we are dealing with a system where a lot of tags are indexed (>10 000) and the TrendMiner system is no longer able to append the index according to requested refresh cycle. In this situation, consider increasing the number of indexing threads, specified in ConfigHub.
Scenario B: historians are all underperforming
Alternatively, but less likely, the performance of all historians is not adequate. Do consult the historian specific metrics to identify the origin of the bottleneck, such as for example throttling due to a network bandwidth issue.
This typically points to an ill performing historian, which you can verify by evaluating the connection metrics in the datasource card.
[1] Usage includes but is not limited to: loaded via dashboards, views, chart, sdk ...
