Monitor for specific events that took under X minutes
Monitoring for specific events that occur within a defined time frame (under X minutes) is essential in the chemical industry for various purposes, such as safety, quality control, and process optimization.
Here are some examples:
Monitoring leaks or abnormal emissions that persist for less than X minutes is vital for environmental compliance and safety.
Detecting rapid temperature changes that occur in less than X minutes is crucial for maintaining product quality.
Monitoring short-term fluctuations in energy consumption can assist in optimizing energy usage within the chemical plant. Identifying and addressing spikes or dips can lead to significant cost savings.
In batch chemical manufacturing, monitoring for events under X minutes helps fine-tune processes for maximum efficiency and product consistency.
Follow these steps:
Create a tag to “Display the duration of specific events as a separate tag.
Create and save a value-based search with the condition where the tag from step 1 is lower than your upper duration limit (E.g. Duration_tag < 25[min]).
In the monitoring menu, set up a monitor for this saved search. Whenever the specific event took under X minutes, TrendMiner will send a notification.
