TrendHub View Tile
Trend tiles bring your data to life by displaying key insights from a TrendHub view, featuring trend plots, stack plots, scatter plots, or statistic tables. Settings configured in the TrendHub view, such as grid lines, context items, trendline filling, and collapsed filters mode, are carried over and make it easier to spot trends and gain deeper insights at a glance.
Available tile settings:
  • Show tile title
  • Show time frame
  • Show component names
  • Show legend
  • Show context items
  1. Start a new or open an existing dashboard.
  2. Select "Add tiles" to create a new tile. You can add the tile to the dashboard by either dragging the tile to the dashboard or double-clicking it. A side panel appears from the right side of the screen.
  3. Add a title of your choice. By default, it takes the name from the view.
  4. Click the "Select a view" to open the work organizer, and choose a view.
  5. Select the trend view of your choice.
  6. Check the “Show context items” checkbox if you would like to also visualize context items directly on the tile. If the “Show context items” checkbox has been selected, context items corresponding to the selected components will appear on the chart.
Hover over the trend tile and click the arrow icon in the top right corner of your trend tile or simply click the title of the trend tile.
Plot
Displays the trend, stacked trend, or scatter plot of your selected view.
Statistics table
Displays a table of descriptive statistics for the tags on the selected plot. This allows you to quickly consult key values - such as minimum, maximum, average, and other statistics - without leaving the dashboard. Only the statistics enabled in the saved TrendHub view will be shown.
You can read more in-depth about the statistics table here.Statistics table
