Trouble shooting (Bas)
Find periods where fouling occurs in your process.
Here you will see how to identify fouling periods, given by a medium-low flow rate and high pressure. Also you will determine the maximal pressure conditions during each event, to quantify the impact.
TAGS: "TM-HEX-FI0620", "TM-HEX-PDI0620", "TM-HEX-PDI0620".
MAIN GRAPH: 20 March 2019 00:00:00 -> 20 June 2019 00:00:00:00 // 3 MONTHS
CONTEXT GRAPH: 20 March 2019 00:00:00 -> 20 June 2019 00:00:00:00 // 3 MONTHSRecording
Learn how to use a value based search to find a given set of conditions that lead our process to fouling and determine how frequently the conditions were met.
Then, add a calculation to each result, to determine critical aggregations (max pressure) and understand the scale of the events.
Find a period of ideal alpha production and compare it to another period where the obtained results were not optimal, to study and identify the differences.
Here you will see how to determine the criteria of what makes a good profile, then visualize that profile to compare all other profiles to it, and distinguish the bad.
TAGS: "TM-BP2*.1" -> "Product", "Conc", "CW", "Temp", "Qual", "Pressure", "Level".
MAIN GRAPH: January 22, 2019 07:00:00 -> January 22, 2019 17:00:00:00
CONTEXT GRAPH: January 13, 2019 00:00:00 -> January 30, 2019 00:00:00:00Recording
Learn how to use a value based search to find all batch periods producing product grade alpha, and identify maximum concentrations achieved. You use this criteria as the ideal. Anything below the ideal product concentration will be quickly identified, and possible causes for lower concentrations can be hypothesized.
