Get your process statistics
You want to know the performance of your main process KPI's during the month of April.
TAGS: "TM-HEX-FI0620", "TM-HEX-PI06202", "TM-HEX-QI0620".
MAIN GRAPH: April 1, 2019 00:00:00 -> April 30, 2019 00:00:00:00 // 1 MONTH.
Recording
In this exercise, you will learn how to get insights from your process statistics (such as total production, max pressure, or quality variability), through the Statistics Table. The obtained results correspond to the period defined in the Focus Chart.
Here you will learn how to filter unwanted periods and present data without them.
When it comes to analyzing our process and understanding the events associated, it's highly likely that there are some periods and some conditions in the data you wish to exclude, or in other words, not take into account.
MAIN GRAPH: March 20, 2019 00:00:00 -> June 20, 2019 00:00:00:00 // 3 MONTHS.
Recording
In this exercise, you will define filter conditions using a value based search to exclude unwanted periods. Use the conditions to create a filter, apply the filter then open up the statistical table to see parameters calculated without excluded periods.
