Tile Configuration
Tile configuration allows you to customize each individual tile. It includes common settings such as the tile title and, depending on the tile type, a data field that can be set to a TrendHub view, a context view, monitors, or other components. Additionally, each tile type offers specific configuration options tailored to its use case.
In edit mode, you can manage an individual tile’s configuration by clicking directly on the tile or selecting "Edit" from the dropdown menu accessed via the three-dot icon.
Furthermore, you can manage the tile’s visualization through tile settings. Below, you will find an overview of the available settings. The refresh settings, accuracy, or even the time span for the graph can also be adjusted.
Tile settings
Tile settings give you control over what information is displayed and how it is presented for each tile. Some settings are universal across all tiles, while others are tailored to specific use cases.
Tile Settings | Current value | Monitor / Alert | TrendHub view | Context view | Text | External content |
Show tile title | x | x | x | x | x | x |
Show timestamp for values | x | |||||
Show component names | x | x | ||||
Show graph for progress visualization | x | |||||
Set chosen colors as background | x | |||||
Show context items | x | |||||
Show time frame | x | x | ||||
Show legend | x | x |
Show tile title: Display the tile title. You can enter a custom title, or for some tiles, the component or view name will be used by default.
Show timestamp for values: Include the timestamp for the retrieved value(s).
Show component names: Show the component name(s), if applicable for the value or the view.
Show graph for progress visualization: Enable a graph for progress visualization, ideal for current values.
Set chosen colors as background: Use the selected colors to highlight specific conditions or statuses as the tile's background.
Show context items: Show the corresponding context items on the view.
Show time frame: Display the time frame of the view or data, similar to the timestamp.
Show legend: Include the legend, useful in cases like scatter plots (e.g., "Oldest to newest").
Other settings
Time span for graph: Define the time span for the historical data used to build the progress visualization graph.
Accuracy: Override the automatic accuracy for the value, specifying how many digits after the decimal point are displayed.
Refresh settings: Set the interval for retrieving data updates.
