Detect, warn & contextualize anomalies and process events (Bas)
You want to be alerted when a process anomaly occurs.
Here you will see how to build a monitor that will trigger an email response when the temperature of your process/asset rises above 120 degrees for at least two minutes.
TAGS: "TM-TSP-TI22114"
MAIN GRAPH: 1 May 2019 9:20:00 -> 1 May 2019 10:20:00:00 // 1 HOUR
CONTEXT GRAPHIC: 1 January 2019 00:00:00 -> 5 May 2019 00:00:00:00
Recording
Learn how to use the Value Based Search to define the conditions to monitor (temp>120, for 2m). Then, enable a Monitor, to provide the option “Send email message”, to be alerted when the anomaly occurs.
