2024.R3.1-14
Lowers the memory requirement threshold to avoid installation failures on AWS.
Fixes an issue where basic auth could break for connections to the connector.
Contains an improvement which avoids unexpected application behavior caused by high database load during the EF live sync startup.
2024.R3.1-13
Fixes an issue with service deployment which causes upgrades to fail.
4.103.11 (connector patch)
Fixes an issue where tags from an ODBC data source can go to index status 'out-of-date'.
Contains an improvement which prevents a PI AF asset sync from stop the asset sync when encountering an unsupported attribute. Unsupported attributes are ignored during the AF sync.
2024.R3.1-12
Fixes an issue where services were not properly started after a reboot or an upgrade.
Fixes an issue where context item workflow names where limited to 64 characters.
4.103.9 (connector patch)
Includes the missing connection pooling diagnostics api endpoint.
4.103.8 (connector patch)
Fixes an issue where the states of digital tags of IP21 tags were no longer shown.
All customers with one or more IP21 data sources are advised to patch their connector.
2024.R3.1-10
Fixes ownership and permission issues introduced by transfer of ownership which can result in monitors no longer triggering correctly.
2024.R3.1-07
Fixes an issue with failing full backup restores.
Fixes an issue where upgrades could fail for installation with the minimal 32GB memory requirement.
Fixes 2 issues where upgrades could fail or access recovery was not working in case of a misconfigured LDAP provider (manager dn password change, LDAP server unreachable, ...)
Fixes an issue with failing context item searches in TrendHub.
Improves application stability.
Fixes an issue with ConfigHub crashes.
Fixes an issue with monitors not being accessible when a fingerprint with deleted tag is saved.
2024.R3.1-06
Fixes an issue preventing the upload of ML Models in MLHub.
Fixes an issue where scheduled full backups show the wrong TrendMiner version if TrendMiner was upgraded since the configuration of the scheduled backups.
Contains security patches for virtual appliance deployments.
Fixes an issue with failing full backup restores for large installations.
Fixes an issue with the ADX provider.
Fixes an issue with the Canary provider.
Fixes several issues in the work organizer.
Improves the reboot time of virtual appliance deployments.
4.103.5 (connector patch)
