Create your own KPIs and variables (Basic)
Here you want to understand clearly the consumption rate of your process.
Calculate the specific consumption of utilities per product flow rate, where production is calculated as the multiplication of the level by the concentration in the reactor.
If you wish to do the exercise, please add the following tag and configure the corresponding time periods.
TAGS: "TM-BP2-LEVEL.1", "TM-BP2-UTIL.1", "TM-BP2-CONC.1".
MAIN GRAPH: January 14, 2019 5:00:00 -> January 14, 2019 13:00:00:00 // 6 HOURS.
Recording
Here you will learn how to build a Formula Tag, that will appear as a separate track on your focus chart, to be used to monitor and track your process and identify peaks that could be anomalies.
You want to calculate the total production of your process.
Here you will learn how to calculate the total production of your process during the last 24h, from a product flow rate measurement.
TAGS: "TM-HEX-FI0620"
MAIN CHART: March 25, 2019 00:00:00 -> March 28, 2019 00:00:00:00 // 3 DAYS.
Recording
Here you will learn how to create an Aggregation Tag to calculate the integral of the last 24 hrs of your process, at all times.
This new tag will become a new process variable displayed in your Focus Chart, and the results will see a running value of production for the previous 24 hours.
