Known Limitations
  • Conditional formatting for the Gantt will not consider any changes to duration propagated through the use of live mode. To see the updated coloring, users must refresh the chart.
  • External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
  • The CSV import fails when importing context items for an asset that does not have any yet.
