Imported data tag
The tag builder import can be used to create a tag with custom data. Some common imports include:
  • Offline measurements
  • Proof of concept for a new datasource, which can be connected later
  • Future data. These can be things like custom time tags (e.g., info on the shifts) or production goals. Note that if we import future datapoints, the tag will appear live in TrendMiner.
Avis
Importing tag data via a file will always be inferior to having a direct connection. If you find yourself often importing files coming from some other system, it is good to check with your admin if a direct connection is not possible. For things like time tags, you could ask if it is not possible to create such a tag directly on the historian.
