Patch Release Updates
2025.R3.0-15
  • Fixes an upgrade issue.
  • Fixes an issue where tags with ‘\' in the tag name could not be loaded by a non-admin user.
2025.R3.0-14
  • Fixes several upgrade issues.
2025.R3.0-12
  • Fixes Ingress-Nginx Security issue CVE-2026-24512
We strongly recommend customers to upgrade.
2025.R3.0-11
  • Includes a significant performance improvement for checking tag permissions which impacts tag searches, loading views, monitors, ...
  • Fixes an issue which can in some cases cause a failure when transferring work between users in ConfigHub.
2025.R3.0-09
  • Fixes an issue where an installation can run out of free disk space when the backup service has insufficient resources.
  • Fixes an upgrade issue where the network speed test fails on RHEL9.7 servers.
2025.R3.0-07
  • Fixes excessive memory usage in the work organizer service.
  • Fixes a bug causing tm-datasource to timeout too fast when fetching assets and context, causing asset and context syncs to fail.
5.0.6 (connector patch)
  • Fixes an issue causing the connection to a Wonderware historian to break after upgrading from a connector version < 4.105.3 with the default connector configuration.
  • Fixes an issue causing a PI AF to be synced only partially.
2025.R3.0-06
  • Includes a fix to improve the resilience of historical context synchronization.
  • Fixes dashboard save issues related to monitor tile configuration.
  • Fixed issue where clickthrough from an active monitor to its fingerprint definition did not work.
  • Fixed issue where a newly created fingerprint could not be selected as a monitor.
  • Fixed an issue where tags consulted exclusively via current value or gauge tiles would incorrectly adopt a reduced forward indexing policy of once per day.
  • Fixed an issue where the regression line on scatter plots was not correctly rendered on Windows machine when making modifications to its configuration.
