Patch Release Updates
2025.R2.0-17
Fixes several upgrade issues.
Fixes Ingress-Nginx Security issue CVE-2026-24512.
2025.R2.0-15
Fixes a bug in the database restore.
Fixes an issue in the work organizer transfer of ownership.
2025.R2.0-14
Fixes an issue where an installation can run out of free disk space when the backup service has insufficient resources.
Fixes an upgrade issue where the network speed test fails on RHEL9.7 servers.
Fixes excessive memory usage in the work organizer service.
5.0.6 (connector patch)
Fixes an issue causing the connection to a Wonderware historian to break after upgrading from a connector version < 4.105.3 with the default connector configuration.
Fixes an issue causing a PI AF to be synced only partially.
2025.R2.0-13
Fixes issues regarding the Context Item sync.
Fixes an issue in which saving a draft Alert tile in DashHub was not possible.
2025.R2.0-12
Fixes a stability issue for large installations which was causing some services to restart frequently.
Fixes a stability issue for custom calculations.
Mails from Cron Daemon to TrendMiner virtual appliance admins with error "No such file or directory" are no longer sent.
Fixes an issue where tags with status "stale" could not be reactivated anymore after the data source issue was fixed.
Fixes some small UI and clickthrough bugs in the index manager.
Fixes an issue where the index policy was not updated after activating a monitor on calculations based on dormant tags.
Improves stability and performance of the live context sync.
Prevents live context sync from auto-disabling after running into errors during the sync.
