Patch Release Updates
4.105.10 (connector patch)
Fixes an issue causing the connection to a Wonderware historian to break after upgrading from a connector version < 4.105.3 with the default connector configuration.
Fixes an issue causing a PI AF to be synced only partially.
2025.R1.0-11
Fixes a stability issue for large installations which was causing some services to restart frequently.
Mails from Cron Daemon to TrendMiner virtual appliance admins with error "No such file or directory" are no longer sent.
Fixes a bug where the context sync scheduler seizes to schedule new background sync tasks. It could happen that background jobs like a nightly cleanup or a historical sync were staying in the WAITING state indefinitely. This should now be resolved.
4.105.8 (connector patch)
Fixes a connection issue for Exaquantum data sources.
2025.R1.0-09
Fixes an issue where basic auth could break for connections to the connector.
Fixes an issue where Asset CSV import could fail if assets where created via the API but deleted via CSV import before.
Prevents EF live sync from auto re-enabling daily after disabling manually.
Fixes an issue with pagination that prevented enabling live sync when more than 20 data sources were present.
Fixes an issue where suggested types in context item creation were not shown when not in first page of type results.
Fixes context type dropdowns not showing correctly for some asset-specific types.
2025.R1.0-07
Fixes an issue where password change did not work.
Lowers the memory requirement threshold to avoid installation failures on AWS.
Fixes several issues with ContextHub caused by a high amount of context item types.
Contains an improvement which avoids unexpected application behavior caused by high database load during the EF live sync startup.
2025.R1.0-06
Fixes an issue with service deployment which causes upgrades to fail.
Fixes an issue where sometimes DashHub tiles don't load (they keep spinning).
Fixes an issue where mails were sent to admins about a background log cleanup process.
4.105.5 (connector patch)
Fixes an issue where tags from an ODBC data source can go to index status 'out-of-date'.
Contains an improvement which prevents a PI AF asset sync from stop the asset sync when encountering an unsupported attribute. Unsupported attributes are ignored during the AF sync.
2025.R1.0-05
Fixes an issue where services were not properly started after a reboot or an upgrade.
Fixes an issue where context item workflow names where limited to 64 characters.
