Known Limitations
- Conditional formatting for the Gantt will not consider any changes to duration propagated using live mode. To see the updated coloring, you must refresh the chart.
- External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
- When calculated tags are deleted, they cannot be created with the same name again.
- After renaming a calculated tag linked to a context item, the component of the context item is not updated correctly.
- The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
- The CSV import fails when importing context items for an asset that does not have any yet.
