Bug Fixes
Numeric Mismatch – Context sync has been repaired to ensure numeric context fields are updated when they are changed in an external system.
Scatter plot update – Scatter plots now update correctly when switching axes while a drawn area is visible.
“Unsaved changes” label in ContextHub – some filter combinations in ContextHub resulted with an erroneous “Unsaved changes” label on the title bar. The label now reflects saved changes as expected.
Fixed an issue where monitors could become system-disabled due to an incorrect tag accessibility check. In rare cases, the tag accessibility failed, even though the monitor was healthy. Improvements are implemented to avoid such scenarios.
