Bug Fixes
  • Fixed an issue where the “|” character parsing for external ID was incorrectly applied.
  • Fixed an issue with the import script where asset paths containing multiple identical string segments would fail.
  • Fixed an issue where the focus chart data export failed when a layer name contained a slash (“/” ).
  • Fixed an issue where test connection was working incorrectly for the HC (Connector-to-Connector) provider. Now when an admin user clicks on the 'Test connection' button, it checks whether the "referenced connector" is reachable and whether the data source exists on the “referenced” connector with the same name. if not, the error will be logged in the log file.
  • No logs for TrendMiner appliances due to rsyslog permission issues are fixed.
