Stepped daily aggregations
The idea is to trick TrendMiner by adding an extra point at the beginning of the day, and then have TrendMiner interpolate that point using the sqrt(-1) function.
The result is a tag that shows daily values as discrete (stepped) tag.
Tag-Builder Formula:
if(and(a<>b,b=c),AGGREGATION_1,
if(and(a=b,b<>c),AGGREGATION_2,
sqrt(-1)))
Variable
Tag
Shift
a
TM_day
1s
b
TM_day
0s
c
TM_day
-1s
AGGREGATION_1
Aggregegation__Forward_24h
0s
AGGREGATION_2
23h 59m 59s
  1. The formula requires an AGGREGATION tag that calculates FORWARD over 24 HOURS with any OPERATOR (Average, Integral,...).
  2. The first if function is TRUE if a is not equal to b and b is equal to c. This is true if the day in TM_day has just changed (Tuesday to Wednesday). Then the new formula day has the value of INTEGRAL_1.
  3. The second if function is TRUE if a is equal to b and b is not equal to c. This is true if the day in TM_day is about to change (still Tuesday, just before Wednesday). Then the new formula day has the value of INTEGRAL_2.
  4. If neither condition is true (both FALSE), the trick, square root of -1 (sqrt(-1)), interpolates between the data points.
