Known Limitations
  • Embedding TrendMiner in external applications is limited to Microsoft teams. Extensions to improve this functionality and make it more robust, will arrive later.
  • External content tiles in dashboard need cookies to properly load all content (and be able to login when required).
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible.
