5.4.3 (CONNECTOR PATCH)
Contains several improvements for the ConfigHub ODBC/JDBC query designer.
2026.R3.0-11
Added an automated pre-upgrade check to verify that the host CPU supports the x86-64-v3 microarchitecture instruction set required by 2026.R3.0 before beginning the upgrade.
Improved export speeds for Context views.
Resolved a
400 Bad Request schema validationerror encountered when connecting to newer Azure OpenAI model endpoints.
2026.R3.0-10
Fixed an issue where wildcard filtering (e.g. using *) on text fields in ContextHub views returned no results.
Resolved an out-of-memory condition in tm-context that caused service restarts and instability.
Fixed an issue where context sync status in ConfigHub diagnostics incorrectly displayed "No Activity".
Fixed an issue where conditional formatting was not applied to the Last Modified Date column in ContextHub.
Fixed an issue in Query Designer where testing a valid index query with no matching records returned an INVALID_SCHEMA error instead of an empty result.
Improved guidance messaging in Query Designer when {INDEXRESOLUTION} or {NUMBEROFINTERVALS} are omitted, clarifying recommendations for query aggregation and performance.
Fixed an issue where query execution errors in Query Designer were not surfaced properly in the frontend UI.
Resolved a pattern validation issue in Query Designer that prevented testing tag names containing spaces or special characters.
Fixed an issue preventing downloaded log packages from ConfigHub from being extracted.
Virtual appliances only: fixed a critical Linux kernel TCP vulnerability (CVE-2026-98432).
Updated trusted root Certificate Authority (CA) certificates across the Appliance OS, Jupyter kernels, and Custom Calculations to remove compromised root certificates and secure outbound external communications.
We strongly recommend all customers to upgrade.
5.4.2 (CONNECTOR PATCH)
Fixed an issue that prevented indexing and plotting data for STRING tags from IP21 data sources.
2026.R3.0-09
Fixed an issue in current value dashboard tiles which could cause an infinite loop, leading to thread exhaustion and recurrent high CPU utilization.
Fixed an issue where access rules on deleted users could cause context permission synchronization issues.
Fixed an issue in ConfigHub diagnostics where live sync incorrectly reported "no activity" even when recent context items were actively syncing.
Fixed an issue where tm-datasource failed to start if there was an issue with a provider during startup.
2026.R3.0-07
Fixed pagination behavior in context search endpoints to return an empty continuation token on the final page, preventing redundant client requests.
Fixed an issue where deleted users were displayed in the user suggestions when sharing items.
Fixed an issue where users were unexpectedly logged out when opening ConfigHub due to token authentication failures on MCP connections.
Resolved an issue where a false "Something went wrong" error toast was displayed on environments without an AI license feature.
Fixed an issue causing Azure Data Explorer (ADX) datasource connections to fail following an upgrade.
