5.2.6 (CONNECTOR PATCH)
Fixed an issue that prevented indexing and plotting data for STRING tags from IP21 data sources.
5.2.5 (CONNECTOR PATCH)
Added a configurable concurrency limit for PHD data sources for improved performance, replacing old connection pooling functionality.
Expanded special character support for IP21 tags.
2026.R1.0-13
Fixes an issue with root volume filling up, causing disk space alert mails being sent. This primarily affects virtual appliances.
Fixes an issue where (monitor) mails were not sent if the email domain cannot be resolved on the server.
Fixes an issue with missing service logs.
5.2.4 (CONNECTOR PATCH)
Fixes critical security vulnerability CVE-2025-6965 in SQLite.
2026.R1.0-12
Fixes an issue where users could be logged out unexpectedly.
2026.R1.0-11
The "ConfigHub recovery" action in Edge Manager now also unlocks the hardcoded admin account.
Fixes an issue where indexing could be stopped after an upgrade.
Fixes an issue which was causing bulk creation of context items to fail.
Fixes and issue with logs filling up the root partition disk space.
5.2.3 (CONNECTOR PATCH)
Aligns the tag sync timeout for the AppHost connector from 100 seconds to 15 minutes, in line with the WebHost timeout.
Default log level for the connector is reverted from
infotowarnto avoid excessive logging (both for AppHost and WebHost).
2026.R1.0-10
Fixes CVE-2026-43284. (virtual appliance only). Customers with a self-managed TrendMiner installation are advized to patch their server.
We strongly recommend to upgrade virtual appliances.
2026.R1.0-09
Fixes CVE-2026-31431 (virtual appliance only). Customers with a self-managed TrendMiner installation are advised to patch their server.
Fixes rare issue with backward indexing getting stuck 'in progress'.
2026.R1.0-07
Fixes an an issue with logs getting cut off.
Web application firewall changes have been applied to resolve an issue with MLHub.
Fixes issues with restoring full backups.
Fixes issue where work items can not be shared with LDAP and SAML users.
We strongly recommend customers to upgrade.
5.2.2 (CONNECTOR PATCH)
Fixes an issue with indexing string tags for PHD data sources.
