Patch Release Updates
5.2.5 (CONNECTOR PATCH)
  • Added a configurable concurrency limit for PHD data sources for improved performance, replacing old connection pooling functionality.
  • Expanded special character support for IP21 tags.
2026.R1.0-13
  • Fixes an issue with root volume filling up, causing disk space alert mails being sent. This primarily affects virtual appliances.
  • Fixes an issue where (monitor) mails were not sent if the email domain cannot be resolved on the server.
  • Fixes an issue with missing service logs.
5.2.4 (CONNECTOR PATCH)
  • Fixes critical security vulnerability CVE-2025-6965 in SQLite.
2026.R1.0-12
  • Fixes an issue where users could be logged out unexpectedly.
2026.R1.0-11
  • The "ConfigHub recovery" action in Edge Manager now also unlocks the hardcoded admin account.
  • Fixes an issue where indexing could be stopped after an upgrade.
  • Fixes an issue which was causing bulk creation of context items to fail.
  • Fixes and issue with logs filling up the root partition disk space.
5.2.3 (CONNECTOR PATCH)
  • Aligns the tag sync timeout for the AppHost connector from 100 seconds to 15 minutes, in line with the WebHost timeout.
  • Default log level for the connector is reverted from info to warn to avoid excessive logging (both for AppHost and WebHost).
2026.R1.0-10
  • Fixes CVE-2026-43284. (virtual appliance only). Customers with a self-managed TrendMiner installation are advized to patch their server.
We strongly recommend to upgrade virtual appliances.
2026.R1.0-09
  • Fixes CVE-2026-31431 (virtual appliance only). Customers with a self-managed TrendMiner installation are advised to patch their server.
  • Fixes rare issue with backward indexing getting stuck 'in progress'.
2026.R1.0-07
  • Fixes an an issue with logs getting cut off.
  • Web application firewall changes have been applied to resolve an issue with MLHub.
  • Fixes issues with restoring full backups.
  • Fixes issue where work items can not be shared with LDAP and SAML users.
We strongly recommend customers to upgrade.
5.2.2 (CONNECTOR PATCH)
  • Fixes an issue with indexing string tags for PHD data sources.
