Patch Release Updates
5.1.6 (CONNECTOR PATCH)
Re-introduced connection pooling for PHD data sources for improved performance.
5.1.5 (CONNECTOR PATCH)
Fixes critical security vulnerability CVE-2025-6965 in SQLite.
5.1.4 (CONNECTOR PATCH)
Aligns the tag sync timeout for the AppHost connector from 100 seconds to 15 minutes, in line with the WebHost timeout.
Default log level for the connector is reverted from
infotowarnto avoid excessive logging (both for AppHost and WebHost).
2025.R4.0-18
Fixes CVE-2026-43284. (virtual appliance only). Customers with a self-managed TrendMiner installation are advized to patch their server.
We strongly recommend to upgrade virtual appliances.
2025.R4.0-17
Fixes CVE-2026-31431 (virtual appliance only). Customers with a self-managed TrendMiner installation are advised to patch their server.
Fixes rare issue with backward indexing getting stuck 'in progress'.
2025.R4.0-15
Fixes an issue with logs getting cut off.
Fixes an issue with logs filling up the root partition disk space.
Web application firewall changes have been applied to resolve an issue with MLHub.
We strongly recommend customers to upgrade.
5.1.3 (CONNECTOR PATCH)
Fixes an issue with indexing string tags for PHD data sources.
2025.R4.0-14
Contains an openssh patch.
Fixes some upgrade issues.
Fixes issue where string tag gets converted to integer in scientific notation in the statistics table.
Fixes issue where exporting value based search result with added integral calculation is failing.
Fixes an issue with an inaccurate calculation of the forward integral aggregation under specific conditions.
Fixes issue where tags with ‘\' in the tag name could not be loaded by non-admin users.
2025.R4.0-12
Fixes several upgrade issues.
2025.R4.0-10
Fixes Ingress-Nginx Security issue CVE-2026-24512.
Fixes a stability issue with custom calculations.
Fixes a UI issue in the index manager causing the tag name to be invisible on small screens.
Fix that filters out recently transferred items from the recent and favorite items on the home page.
2025.R4.0-07
Contains a significant performance improvement for the tag search.
Fixes issue with the stability of the queueing service.
We strongly recommend customers to upgrade to avoid performance issues.
5.1.2 (connector patch)
Fixes an issue which breaks Aveva PI connections after an upgrade in case no username/password is filled in (PI Trust).
Fixes an issue which breaks connections based on SQLite after an upgrade due to a missing dll.
2025.R4.0-06
Includes a significant performance improvement for checking tag permissions which impacts tag searches, loading views, monitors, ...
Improves the last-value endpoint which is used in the DashHub current value tiles.
