5.3.2 (CONNECTOR PATCH)
  • Added a configurable concurrency limit for PHD data sources for improved performance, replacing old connection pooling functionality.
  • Expanded special character support for IP21 tags.
2026.R2.0-10
  • Contains some internal firewall improvements which could cause some issues with charting, searches or creating items in TrendHub.
  • Cleans up old log files, making log uploads easier/faster.
  • Fixes an issue causing remote backups to Azure or AWS to fail.
  • Fixes an issue causing the restore of a remote backup from Azure or AWS to fail.
  • Prevents restoring a failed remote backup.
  • Fixes an issue where all monitors can stop firing alerts in case of a permission change for one of the monitors.
  • Fixes an important issue with the EF live sync.
  • Fixes an issue where the tag dependency browser incorrectly marked a tag-builder tag as owned by the current user.
2026.R2.0-09
  • Fixes an issue with root volume filling up, causing disk space alert mails being sent. This primarily affects virtual appliances.
  • Fixes an issue where (monitor) mails were not sent if the email domain cannot be resolved on the server.
  • Fixes an issue with missing service logs.
  • Fixes an issue with saving the homepage configuration in ConfigHub.
  • Fixes an issue where 'Last Modified' date is only shown for the first 15 recently used views in TrendHub.
  • Fixes a small UI issue for Firefox users.
5.3.1 (CONNECTOR PATCH)
  • Fixes critical security vulnerability CVE-2025-6965 in SQLite.
  • The AppHost connector now also supports Wonderware x64.
2026.R2.0-08
  • Fixes issue with chart data export (xlsx) and search result export.
  • Fixes an index manager filter issue.
  • Added feedback message when downloading connector logs in ConfigHub.
