Patch Release Updates
2025.R3.0-11
Includes a significant performance improvement for checking tag permissions which impacts tag searches, loading views, monitors, ...
Fixes an issue which can in some cases cause a failure when transferring work between users in ConfigHub.
2025.R3.0-09
Fixes an issue where an installation can run out of free disk space when the backup service has insufficient resources.
Fixes an upgrade issue where the network speed test fails on RHEL9.7 servers.
2025.R3.0-07
Fixes excessive memory usage in the work organizer service.
Fixes a bug causing tm-datasource to timeout too fast when fetching assets and context, causing asset and context syncs to fail.
5.0.6 (connector patch)
Fixes an issue causing the connection to a Wonderware historian to break after upgrading from a connector version < 4.105.3 with the default connector configuration.
Fixes an issue causing a PI AF to be synced only partially.
2025.R3.0-06
Includes a fix to improve the resilience of historical context synchronization.
Fixes dashboard save issues related to monitor tile configuration.
Fixed issue where clickthrough from an active monitor to its fingerprint definition did not work.
Fixed issue where a newly created fingerprint could not be selected as a monitor.
Fixed an issue where tags consulted exclusively via current value or gauge tiles would incorrectly adopt a reduced forward indexing policy of once per day.
Fixed an issue where the regression line on scatter plots was not correctly rendered on Windows machine when making modifications to its configuration.
