Patch Release Updates
2025.R2.0-14
  • Fixes an issue where an installation can run out of free disk space when the backup service has insufficient resources.
  • Fixes an upgrade issue where the network speed test fails on RHEL9.7 servers.
  • Fixes excessive memory usage in the work organizer service.
All customers are advised to patch their installation.
5.0.6 (connector patch)
  • Fixes an issue causing the connection to a Wonderware historian to break after upgrading from a connector version < 4.105.3 with the default connector configuration.
  • Fixes an issue causing a PI AF to be synced only partially.
2025.R2.0-13
  • Fixes issues regarding the Context Item sync.
  • Fixes an issue in which saving a draft Alert tile in DashHub was not possible.
2025.R2.0-12
  • Fixes a stability issue for large installations which was causing some services to restart frequently.
  • Fixes a stability issue for custom calculations.
  • Mails from Cron Daemon to TrendMiner virtual appliance admins with error "No such file or directory" are no longer sent.
  • Fixes an issue where tags with status "stale" could not be reactivated anymore after the data source issue was fixed.
  • Fixes some small UI and clickthrough bugs in the index manager.
  • Fixes an issue where the index policy was not updated after activating a monitor on calculations based on dormant tags.
  • Improves stability and performance of the live context sync.
  • Prevents live context sync from auto-disabling after running into errors during the sync.
