Current value tile
The Current Value tile allows you to easily track the most recent value of one or more selected components. After selecting the components, you can set conditions using operators to highlight specific value ranges, making it easier to visualize the condition of your data at a glance. Additionally, by customizing the tile, you can choose to visualize a graph for progress visualization.
Available tile settings:
  • Show tile title
  • Show timestamp for values
  • Show component names
  • Show graph for progress visualization
  • Use chart aliasTile Configuration
  • Set chosen colors as background
  1. Start a new or open an existing dashboard.
  2. Select "Add tiles" to create a new tile. You can add it to the dashboard by either dragging the tile or double-clicking it.
  3. A side panel appears from the right side of the screen.
  4. Add a title of your choice. By default, it takes the name of the first component.
  5. Click Add component to select at least one or more components. You can add up to 15 components per value tile.
    Each component has an unconditioned state by default but can have multiple conditions added by clicking the Add condition button.
    Conditions let you highlight a component's current value based on defined rules. If a condition is met, the corresponding color is applied. You can add multiple conditions, and only the first matching condition is used. The first option is always Unconditioned, which means its color is applied by default or when no other conditions are met.
    For analog and discrete tags, you can use the following conditions: greater than, greater than or equal to, less than, less than or equal to, equal to, not equal to, between, and not between.
    For digital and string tags, the available conditions are: equal to, not equal to, contains, and does not contain.
  6. Tile settings
    You can find a complete overview of the available settings for the current value tile on the tile configuration pages.Tile Configuration
