Known Limitations
  • Conditional formatting for the Gantt will not consider any changes to durations propagated through the use of live mode. To see the updated coloring, users have to refresh the chart.
  • External content tiles in the dashboard need cookies to properly load all content (and be able to login when required).
  • The action displayed on the right-side panel of ConfigHub when a service is restarted, is no longer visible, these are visible in EdgeManager.
  • The Jupyter notebook files and PMML models are not backed up automatically by TrendMiner in this release. On-premise migrations are still to be done manually by customers by downloading the PMML models and then uploading them on the new system.  This is not the case for customers migrating from Azure to AWS with Cloud Storage where back-up is done automatically with Velero.
  • Notebooks can be shared with other users in the Work organizer. Without “Save-As” functionality, only the original author of notebook can make changes to the shared notebook.
  • Administrators can only transfer the entire contents of a home folder, not individual items. Transfers are irreversible and apply to all items within a home folder.
Notice
Important:  As from the 2024.R3.0 release onwards, the minimum system requirements will become required and validated:
  • vCPU 16
  • RAM 64 GB (up from 32 GB)
  • Disk space 500 GB
Note: In case you are foreseeing issues in (timely) upgrading your system resources, please contact your CSM for more information.
For more details visit the online documentation.
