Data and image export
Exports
TrendHub has different options to export data, which can be grouped into 2 categories:
All export options related to TrendHub Views can be found in the actions list of your view bar.
Clicking the export button reveals a side panel where you can choose one of the following possibilities:
Chart visual: Export the focus chart graph including all visible tags and/or attributes.
Chart data: Export interpolated index data from the focus chart for all visible tags and or attributes.
Statistics data: Export the statistics data of the base layer for all active tags and or attributes (hidden ones included).
Compare layer data: Export the compare layers data of all active tags and/or attributes (hidden ones included).
Color of tags or attributes
Name of the tag or attribute
The parent's name of an attribute (not applicable for tags)
Description of tag or attribute (if available)
The shift of the tag or attribute (if applied)
Units of measurement (if available)
Line style of the layers
Name of the layer (default value 'Layer')
Start and end date and time of the layers
Timezone, this setting lets you choose the desired time zone. This setting is also saved for your user which means that in the next session, it is automatically set to the last used timezone. This is useful when sharing exported files with colleagues in different areas. This setting is also saved for your user which means that in the next session, it is automatically set to the last used timezone.
Chart data resolution, this setting lets you adjust the resolution of points to be included in the Excel file. The overall minimum resolution is set to the indexing resolution which depends on your setup (1 minute by default). The exported Excel file itself is limited to include maximum 1 million points. Therefore, the allowed minimum resolution will scale based on the visualized window, the number of visualised tags, the number of visible layers.
Filter, when having periods filtered out, you can exclude these periods in the export file. Learn more about filters in this document.
Revisit the chart data resolution option after checking the exclude filter option. Since less data points will be exported, the chart data resolution can potentially be increased.
Start and end date and time of the focus chart in the selected time format.
Start and end date and time of the focus chart in UTC format.
All information about the tags and attributes is shown, including:
Parent name (only applicable for attributes)
Attribute name (only applicable for attributes)
Tag name
Description (if available)
The time shift of the tag or attribute (if applied)
All descriptive statistics.
The tag and/or attribute details on the left, including:
Tag name
Layers details on the right which contain the following:
Layer name (and mentioning of base layer)
Start and end date and time of the layer in the selected time zone
Start and end date and time of the layer in UTC format
Value of the current statistics
You can also export search results into an Excel file. Please read the this document to learn more about performing searches in TrendHub.
As soon as a search is executed, the search results, with all available calculations, can be exported. To export search results, simply click the three-dot options button in the results header, followed by the "Export" option.
You can now select the results you wish to export and select the desired timezone before the export is started.
The exported Excel file consists of 2 tabs:
A first, summary tab containing the details of the search conditions
A second tab containing the details of the search results
On the first tab you will see the following details about the search:
Name of the search (if available; this only applies for saved searches)
Description of the search (if available; this only applies for saved searches)
Search type
Settings of the search including
Queried tags
Queried time period (similarity search)
Minimum score (similarity search)
Weights and period of weights (similarity search)
Searched period (Context period)
Export details like timezone and export date
On the second tab of the export file, you can find the following information of the search results:
Start and end dates in the first two columns
The duration of the search result
Search specific parameter (E.g., score for similarity search results)
1 additional column per available calculations
Search export can be downloaded in the notification center once created. The download also stays available for 7 days before it 'expires'.
