Bug Fixes
  • Fixed an issue where the export of value based search results failed if the search definition contained a condition to find all states of a digital/string tag, and the tag has a lot of states. The definition of this search was too big to be exported to Excel.
  • Fixed an issue where unsubscribing to monitor alerts did not work if capitals were used in the email address configured in the monitoring notification.
  • Fixed an issue where importing an asset structure in CSV format, containing empty spaces or lines at the end of the file would result in errors and an unsuccessful import.
  • Previously, when a user selected a subfolder as location for publishing notebook pipeline in MLHub, it was published in 'My work' folder instead. This bug is fixed now and pipelines are published in the correct folder.
  • Fixed an issue where the CSV import failed when importing context items for an asset that did not have any yet.
As of 2024.R2.1
  • Fixed an issue where the indexing of ML tags failed because of special characters in the tag name.
  • Fixed an issue where filtered search results were not immediately reflected on the axis in the parallel coordinates plot, requiring tab switching to update.
  • Improved scrolling behavior when some notebook outputs are shown or a cell is added.
