Application Enhancements
  • Connector Ecosystem – The Shiftconnector Plug&Play connector now supports Shiftconnector 7.22, with under-the-hood improvements for authentication compatibility and enhanced event synchronization performance through the Shiftconnector new Reporting API.
  • Connector Ecosystem - The Canary Plug&Play connector has been tweaked to increase performance, resulting in a 4x faster indexing of Canary tags.
  • Connector Ecosystem - Added the ability to configure the retrieval mode for tags in the Aveva Wonderware provider, allowing administrators to select the mode best suited for their analysis needs.
  • Modifying search based filters – It is now possible to modify a saved search based filter in TrendHub, which allows you to easily switch between a filter that includes or excludes time periods based on the search result.
  • Event Analytics configuration – The Event Analytics configuration pane has been extended and now provides the option to hide calculations on digital or string tags from the table and histogram overview.
