Text tile
The text tile is a key element of your dashboard, allowing you to display both short and long texts in a visually distinct way. Unlike other tiles, the text tile loses its background color in presentation mode, maximizing the space available for displaying content.
Start a new or open an existing dashboard.
Select "Add tiles" to create a new tile. You can add the tile to the dashboard by either dragging the tile to the dashboard or double-clicking it.
A side panel appears from the right side of the screen.
Add a title of your choice.
Click “Edit text content”
This will show a modal where you can add, adjust and remove formatting.
Basic options | Explanation |
Bold | Set the selected text in bold. |
Italic | Set the selected text with a slope to the right. |
Underline | Adds a line underneath the selected text. |
Align left | Align text with the left margin. |
Align middle | Align text in the middle with the same space between the left and right margin. |
Align right | Align text with the right margin. |
Unordered list | Starts a list with no inherent order (bullets). |
Ordered list | Starts a list with inherent order (numbering). |
Undo | Reverse the effect of a previous action. |
Redo | Cancel the undo action. |
Create table | Start creating a table to be included in the tile. |
Delete table | Remove a complete table. |
Show more | Reveal more options. |
Clicking on the "Show more" button reveals more options. Which can be hidden using the "Show less" button.
Advanced options | Explanation |
Strikethrough | Add horizontal line through the text. |
Subscript | Distinguish a symbol or text below and to the right of another character. |
Superscript | Distinguish a symbol or text below to the above and to the right of another character |
Justify | Space is added between words so that both edges of each line are aligned with both margins. |
Paragraph | Change the format of the text that affects an entire paragraph including alignment, font type, font size highlighting and indentation. |
Font size | Update the current font size. |
Text color | Update the color of the selected text. |
Background color | Update the background color of the selected text. |
Indent | Adds a point under the previous point (bullet or number). |
Outdent | Moves the point under the previous point to the previous level. |
Link | Make a clickable link to another web resource. |
Unlink | Remove a link that has been set. |
Add column before | Add a column on the left of the column the cursor is located. |
Add column after | Add a column on the right of the column the cursor is located. |
Add row before | Add a row above the row the cursor is located. |
Add row after | Add a row below the row the cursor is located. |
Delete column | Delete the column where the cursor is located. |
Delete row | Delete the row where the cursor is located. |
Merge cells | Merge the selected cells together in one. |
Split merged cells | Split merged cells into the original state. |
Show less | Hide the advanced options. |
