Patch Release Announcements
2024.R1.0-17
Fixes a memory leak in Edge Manager when inspecting the live logs. Customers frequently using live logging in Edge Manager are advised to upgrade.
Fixes several minor bugs in ContextHub, monitors and ADX.
2024.R1.0-13
Fixes an issue which prevents the upgrade to 2024.R2. All customers running on a 2024.R1.0 patch release 12 or lower MUST upgrade to 2024.R1.0 patch release 13 or higher before upgrading to 2024.R2.
4.78.28 (connector patch)
Fixes an issue where the 'Test connection' always failed (also for successful connections) when adding a new PI AF or APRM data source in ConfigHub.
2024.R1.0-13
Fixes an issue with a failing LDAP sync if the sync took longer than 5 minutes. Customers who experience LDAP sync issues are advised to patch.
Fixes several issues in ContextHub which can lead to performance degradation, components for context item creation as part of a monitor alert being deselected or failing ContextHub view exports. All customers who actively use ContextHub are advised to patch.
4.78.27 (connector patch)
