Application Enhancements
  • Context Items on TrendHub tile – context item bubbles are now visible on TrendHub tiles.
  • Wonderware Support – Wonderware 2020 and 2023 are now supported historians.
  • APRM v14 support & Improved APRM connectivity – events without start dates will no longer be synched, while properties of all types are being synced to a Context Item in TrendMiner.  Designators will now be propagated to all levels of a batch (for example, Batch ID).
  • TrendHub view details – when saving a view in TrendHub, a complete summary is provided which reflects what is saved.
  • Improved Security on ConfigHub Access – ConfigHub now uses the same authentication system as all other users and there will no longer be a default password.  The principal ConfigHub admin user will now require 2 Factor authentication.  Additionally, ConfigHub access can now be reset using Edge Manager.
    ConfigHub access will need to be reconfigured after the upgrade. All details on the changes and how to reconfigure your ConfigHub access after the upgrade can be found here.
  • System Administrator Role – a new role has been introduced to be used for ConfigHub Administration access, in addition to the existing Admin role called “Application Administrator.”
    All details on the different admin roles can be found here.
  • Structural changes related to configuration of the TM installation – SSL and license configuration have been moved to EdgeManager.
  • In-app user guide language additions - user guide is now available in Spanish.
  • Improved sorting on tables – leading spaces, punctuation and capitalization will now be ignored for a more logical alphabetical sorting on tables (e.g. ContextHub view, Work Organizer).
  • Restoring a session - opens the view directly now, instead of returning to the “Home page” first.
