How can the language be changed?
All main TrendMiner Hubs are since the 2020.R2 release available in the following languages:
English
German
French
Spanish
Portuguese
Dutch
Mandarin & Simplified Chinese
The language which is presented to you, depends on the language setting of your browser and can be changed in the browser settings.
After changing the browser language setting a refresh of the page or a re-login might be needed before the changes are reflected in the interface.
Instructions on how to change the language settings of the most common browsers can be found via following links:
The steps to change the browser language settings are browser dependent and might change over time. If you can’t find the right instructions in the list above, we recommend searching the exact instructions via a search engine of your choice.
